11 members (Woodcmiami, tonyt, DannyW, Bill Hanlon, walter74, gswbbc, baldeagle, lumbersawyer, Otto Skorzeny, JW51, 1 invisible),
86
Mod | | | Forums66 Topics128,040 Posts1,055,475 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 53 | The more than large cylinder for my dump bed appears to be leaking at both ends. Is anyone familiar with this animal? Is it just a gasket replacement? Are there any tricks or precautions when working with these machines? | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | If it is more than a hydraulic hose/fitting then the cylinder must be removed for proper repair. It has a packing at the rod end but I don't believe it has anything other than a welded base. If there really is a leak at the base then it may require a much more in depth repair such as replacement of the barrel. After you thoroughly clean the cylinder you may discover that it is oil running down from the rod end and making it appear it's leaking at the bottom. You don't say it but it is assumed that this is an underbody hoist and not a front mounted telescopic. Precaution must be taken at every turn to adequately block the body before attempting removal. That shouldn't have to be stated but there it is. Better yet let a pro do it. I know all the body upfitters in OR so if you need a reference I can help you. | | | | | Joined: Feb 2011 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 53 | Thank you for the info. I would appreciate the references. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | You neglected to say where in OR you are. | | | | | Joined: Feb 2011 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 53 | I actually live in Washington just outside of Portland. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | In PDX I recommend both Northwest Truckstell or Airport Blvd. and the Isuzu/Hinl dealer on MLK just north of Columbia Blvd who has an excellent body/equipment shop. | | | | | Joined: Feb 2011 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 53 | You sure know your way around Portland for a Colorado boy. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I've traveled the Pac NW since 1987. I love Portland except for the way to the left politics. I know my way around Seattle, Vancouver, Calgary, Edmonton, Boise, and everywhere else in the NW. I love it there and it's been very good to me. | | |
