| | | Forums66 Topics128,051 Posts1,055,711 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Hey guys. Anyone haqve any experience with this? I'm replacing my front crossmember on my 57 3100. I think its too wide to just slip into place, since it fits up inside the c-channel frame rails. I was thinking of unbolting the bumper, core support, and springs, and jacking the rails apart enough to get it in. Opinions? Easier alternatives?
regards, Leon | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Is the frame tapered? Can you put it in fruher bac and hammer it forward?
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | cletis, I have the BFH in reserve, in case there's no more elegant way.
highflyer, AD frames are tapered. TF frames are straight, to make room for the v8s.
regards, Leon | | |
