2 members (Nick in Manitou, 1 invisible),
304
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | s, and all the other black painted parts. I ordered some from a parts place and all it is, is a gloss black. Does anyone know the correct stuff to use?
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | I would and have used Rustoleum semi gloss black.
Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | should be a satin black as is sometimes called frame and chassis blackBill | | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | The rustoleum satin is close to what it should be, I don't want to use it on this project. Why? Because I am not sure about the UV ability of rustoleum. I know another brand that can be matched and will have UV protectant added. I don't want to have the parts cloud up from UV. Same goes for the chassis black, like eastwood is it UV resistant?
| | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | I just wish I could find a decent part that still has original sheen etc to go match it with. Gosh some patch panels with EDP are very close.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes, the EDP on modern replacement parts is very close ... check for original appearance where the flange of the inner laps the fender .... parts on my current daily driver done with Tremclad, the CDN Rustoleum, have held up fine with 15 years of constant use in this climate
Bill | | |
