0 members (),
138
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | Thanks in advance!!
1955-59 Chevy Truck
I recently replaced the generator with a 3 wire GM alternator which is charging but the AMP gauge does not show charge...infact when key is in on position and when motor is turning the AMP gauge goes to the left. I have unplugged the old voltage regulator and wired the battery wire from the ALT directly to the starter wire.
Anyone have a wiring suggestion so the AMP gauge reads charging. I want it to show charging. Thanks a bunch | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if the amp gauge is moving there's a flow happening, try reversing the wires on it and it should read charge instead of discharge .... whether it comes back to 'neutral' when the battery is fully charged will be the next question  Bill | | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | Hey Bill....The gauge has 3 wires plugged into the back. There are 2 possible blades on one side and 2 blades on the other. Out of the four possibilities, there are like I said 3 wires plugged into the back of the gauge. Have any idea what blades should have a wire and where they are SUPPOSED to be coming from from the factory? Thanks my man | | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | I forgot...One of the wires was going to the horn relay and has a jumper going somewhere. I am restoring this thing and getting pretty close to being on the road...just want the amp gauge showing charge...It is charging for sure cause I have checked.
Thanks again | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | each sides pair of tabs are actually a single connection with provision for 2 wires - factory diagram shows 2 wires on passenger side [to ignition sw and lite sw] and 1 wire on drvr side to battery connection on the starter .... the horn relay originally got power from the regulator, must have been changed because of the alternator?
by the diagram, I believe the regulator would have fed the generator power to the terminal on the light switch and from there thru the ammeter to the battery - with the alternator direct to the battery[starter post] the current to the gauge is going backwards - pretty sure reversing wires on the gauge will make it show charge, but that's not really the correct way to wire it
Bill | | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | That's probably it Bill....I know that one was coming from the original voltage regulator and now is disconnected. I will check to see where the wires go tomorrow morning an get back to ya with the results. I have pretty much cleaned the last guys wiring mess up so far....Looks like an idiot kit but some things were going to the wrong places and I am by NO means an electrical genious. Maybe you can help me with this too...I changed to 2 wire new front park/turn lamps. How the heck do I wire the lamps so they are on with the headlights? They currently work for turn signals only. Sure I will eventually figure it out but thought I would ask before I pull the rest of the nubs from my bald head...lol
Thanks again, Steve | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | do you have a wiring diagram [like in the shop manual]? if you notice there's a line marked "front of dash panel" which orients the diagram front/back, left/right and the components and wires are positioned in the truck exactly as on the diagram .... for the signal wiring see here there's a diagram on page 5, there should be 2 seperate wire circuits for park and turn that connect to a plug on the rad support from the harness and from the light socket Bill | | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | Yep...got that diagram...I am going to head out to the garage in the morning to first figure out the amp gauge charging issue.
The other issue was wiring the turn signals so they are also on with the headlamps...I like that look!! I think I got the what to do in my head and want to head out there but then again it is late. I'll check it out and get back to ya minana my man..
Thanks, Steve | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Your park lights weren't wired to run with the head lights. If you want them to you will have to rewire them at the switch. Then, unless you do some fancy trick wiring, you won't be able to use park lights separately. | | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | Hey Cletis...long time.
I have done it once many years ago and remember I had to do some weird stuff but they lit up with the headlights and still maintained the turn signals. Think I got the solution and will try it in the a.m. Take care
Steve in I-DA-HO | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy bigdog58, if you ran the output wire of the new alternator directly to the battery you bypassed the ammeter, and now the ammeter only reads discharge. If you still have the "Bat" wire available to you from the old regulator, hook the alternator output to that, that will restore everything to what it should be, hope that helps.
