0 members (),
84
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | I have 3 or 4 AC glass bowl fuel pumps. Where can I find rebuild kits for these?
Walt Williams La Verkin, UT | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Same as the non glass bowl AC pumps with exception of the cork gasket for the bowl. Jim Carter is supposed to have them although in another thread they are said to be expensive now. I think I tried NAPA not to long ago with no success, but I'd try them again to be sure. Grigg | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | See my recent results on mating a glass-bowl top to a metal-top bottom. Grigg and Tiny helped me make the union. I'm a dufus and definitely no expert, but if my Frankenpump continues to work, looks like it could be a cheaper / easier alternative to doing a rebuild. Don't know if you could pull the valves out of the top of the metal pump and put into the glass pump. The cork gaskets for the glass bowl are a couple of dollars at Chevs of the 40's and other suppliers.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Aug 2010 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 38 | Chevs of the 40s has a kit for around $40.00 or so. I do not know howngood the material is with the tainted gas we have to use. | | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | 54belair, Try the Filling Station in Lebanon, OR too. They have an online catalog and it shows they do have some in stock. Also kits for all variations of single barrel carbureters from the 20's, 30's,40's and 50's. Normbc9 | | | | | Joined: Jun 2011 Posts: 3 New Guy | | New Guy Joined: Jun 2011 Posts: 3 | I may be wrong, but I just got a kit for a 42 Ford COE and it looks exactly the same as my 30 Chevy and 53 Dodge. Macsautoparts.com has them for a mere $19.50. Part # 11A-9349 The diaphragm is usually the only part that needs changing and the rest go back in the bag and sit on the shelf... They also have the earlier diaphragm without the metal part if you need that. Good luck! | | |
