3 members (Shaffer's1950, Bill Hanlon, Gdads51), 96 guests, and 3 robots.
Topics128,150
Posts1,056,985
Members48,460
Just purchased new stainless brake lines from inline tube for my 1937. Looks good except for the line from the master cylinder to the main block. Having problems disconnecting the old lines. Any suggestions. Thanks
I just pulled my rear brake lines this weekend. Yesterday, couldn't budge them - they were rusty where the line met the fitting. I sprayed kroil on them and tried today. I got them turning & off on the wheel cylinder side with a vise grip. Once I got the end at the cylinder off, I was able to slice a wrench over the fitting and down to the other fitting. If worse came to worse I figured I could cut the line to allow me to slide the wrench on, but didn't need to. A couple of wacks with a hammer loosened the fitting. I think the soaking 24 hours with lots of kroil helped.
Thanks, I will try that. Are you in Chicago, I am in Manhattan, IL
If you are not saving your old lines, cut them near the fitting and let the whole thing turn. That will make them easier to get off.
1951 1 Ton Completed
And use a 6 point socket once you cut the line near the fitting.
The use of tubing wrenches works in most cases.
Yes, cletis, in MOST cases. I actually BROKE a New Britain tube wrench on the rear of my '40!! Should have tried the Kroil!!!:)
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
