4 members (1955firstseries, Paul Mullen, Shade Baby, RLB), 72 guests, and 4 robots.
Topics128,192
Posts1,057,228
Members48,465
Hi All I did put in a new diaphram in the two speed on rear end but still does not work any ideas?
3B Offline
Hy crockbuyer, have you checked the system, is the control valve connected to the engine vacuum. If it is, have you checked for vacuum at the rear axle with the shifter knob in both positions?
First, check to see if the 2-speed can be shifted manually by moving the linkage the diaphragm is attached to. If it works that way, then track down the source of the loss of vacuum to the diaphragm. You could have a faulty shift valve, or a leak in one or more of the lines from the valve to the rear axle.
