| | | Forums66 Topics128,188 Posts1,057,216 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 48 | Hi All I did put in a new diaphram in the two speed on rear end but still does not work any ideas? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy crockbuyer, have you checked the system, is the control valve connected to the engine vacuum. If it is, have you checked for vacuum at the rear axle with the shifter knob in both positions? | | | | | Joined: Feb 2004 Posts: 29,876 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,876 | First, check to see if the 2-speed can be shifted manually by moving the linkage the diaphragm is attached to. If it works that way, then track down the source of the loss of vacuum to the diaphragm. You could have a faulty shift valve, or a leak in one or more of the lines from the valve to the rear axle. Jerry
