| | | Forums66 Topics128,127 Posts1,056,674 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#73651 02/21/2007 5:08 AM | Joined: Apr 2002 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 99 | I am writing this question on behalf of my brother-in-law. He has a motor home that is powered by a 454. It just blew at least 2 and maybe 3 pistons. He is considering replacing just these failed pistons, rings, etc. The engine shows about 65,000 miles but is 15-20 years old. Its past maintenance, storage history and use is unknown. Last summer he had it out in west Texas from Michigan and had to have a new, larger radiator fabricated to get the tempature down into an acceptable operating range. Previously it had always been runnig very hot but never boiled over. He wants to rebuild while the engine is still in the motorhome. To pull engine he would have to first pull it up into motorhome and then out the door.
I told him that before he does all that work on just those 2 or 3 cylinders he should consider the following:
1. Power difference in these rebuilt cylinders vs. the other 5 or 6 that would not be rebuilt could cause problems with balance, power, another weak link, etc.
2. Having to go back in again to do other cylinders would double labor and consumable parts like gasket kits and other parts not related to the dead cylinder(s).
I have no dog in this fight. I just don't want him to be penny wise and pound foolish. If I am way off base in concerns just tell me so, I have very thick skin and can take the heat!
Thanks to all,
Bob | | |
#73652 02/21/2007 6:33 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | What does he mean by failed pistons? I'd think knowing the pistons are failed means the heads have already been pulled off, and getting the rest of the motor out might not be that big of deal.
On my motorhome I could remove the motor out the front rather than through the passenger compartment.
Also it would make sense to understand why it was running hot to make sure that problem is addressed before spending much on fixing the motor. It would be too bad to spend those bucks only to find the problem was caused by excess heat.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#73653 02/21/2007 2:12 PM | Joined: May 2005 Posts: 17 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 17 | I agree ith OldSub! BB's do not like heat. My past experience with BB's is drop valves. I would find a way to pull, tear down & see at what extent of the damage is. Good luck! | | |
#73654 02/21/2007 5:02 PM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | do it once....do it right... he'll be sorry if he half a$$'$ it.... | | |
#73655 02/21/2007 5:10 PM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy J D Bob and guys, I agree with you, we have to know why they failed, and how close to failure are the rest of them. It's time to take the engine out and take it completely apart to evaluate what you actually have, you will be a lot happier in the long run, knowing exactly what kind of shape all the parts are in, do a quality job now, hope that helps. | | |
#73656 02/21/2007 11:05 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | That would be near impossible to do with it in the chassis. There vis a huge crossmember under it. I would get a reman from either Jaspers or G.M. They are expensive but so is breaking down on the highway. Burnt pistons are usually from too much spark timing. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
