0 members (), 61 guests, and 4 robots.
Topics128,024
Posts1,055,395
Members48,422
#73638 10/02/2007 12:20 AM
Apprentice
Apprentice
i have a 66 c-10 stepside with a 350 chevy
and turbo 400. i plan on removing this engine
and replacing with a better 350. some say to remove tranny with engine. i have worked and rebuilt engines on stands, but have never removed one. if i leave the tranny in is it easier??? anything special to do, does converter stay right in place?? any comments appreciated
#73639 10/02/2007 3:23 AM
In my 64 I pulled both at once, and vegly remember sliding the tranny crossmember back first. Also remove the drivshaft first and have a drip pan ready for the tranny fluid that will drible out the tail end of the tranny. (make sure you drain all fluids first and I always have a bag of absorbant or kitty litter handy.
#73640 10/02/2007 3:29 AM
This is a very heavy assembly....I certainally wouldn't go to remove a turbo 400 attached to a 350 engine - especially if youre' only going to replace the engine itself. For one thing, you'll need an ideal hoist situation and a lot of vertical clearance - better get two other guys to help you.
J.D. Jordan
#73641 10/02/2007 3:32 AM
Welcome. Its kinda 6 of one, half dozen of another-if you leave the trans in, no huge fluid loss+underneath time is minimum-no unbolting of crossmember-but the bellhousing bolts are a bear(somewhat easier w/a long box end 9/16)to get to. You'll need a jack under the trans. Pulling both is obviously heavier. Lining the engine back up to the trans in the truck when replacing it can be a pain, with both engine/trans together its easier to put into place in the frame . Either way the heater box needs pulled to make room.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#73642 10/02/2007 3:38 AM
The last time I swapped a motor in one of these I left the transmission in place.
I remember being in a hurry and wanting to swap the motor from one to the other, and vice versa, in a single weekend. It worked. I drove both away Sunday night.
#73643 10/02/2007 12:10 PM
Apprentice
Apprentice
thanks for all the replys, looks like you need
alot of tilt to remove and replace with tranny included, ill keep posted on which way i chose, gotta roundup some help----john
#73644 10/02/2007 8:16 PM
Riding in the Passing Lane
If you don,t need to pull the trans. leave it in there. Much easier. You won,t even need helpers.
1972 Chevy c10 Cheyenne Super
#73645 10/03/2007 12:02 AM
Apprentice
Apprentice
thanks, george, nice trucks you have there
#73646 10/03/2007 12:04 PM
Apprentice
Apprentice
if i leave the tranny, what would be the procedure, will tranny drop down at all, should
it be supported?? bellhousing bolts, hard to get to?? splineing back up, easy??
#73647 10/03/2007 1:49 PM
Unbolt the flywheel from the converter. Put a bottle jack with a block of wood under the trans. Remove the trans. to engine bolts. They shouldn,t be to hard to reach. Use a long extention with a swivel socket. Remove the engine mount bolts & everything attached to the engine. Get a engine pulling plate that attaches to the carb mounting. Pull the radiator & fan & hoist it out. With a cherry picker I don,t pull the hood. Just remove the front 2 bolts & loosen the back 2 & tip it back & put blocks of wood it to hold it back. It,s no problem going back with an automatic. Just pull them together & put in a couple of bolts & let the whole thing down on the mounts. Isn,t this fun.
#73648 10/06/2007 10:26 PM
Apprentice
Apprentice
removed engine today, left tranny in, left
hood on, smooth as silk, thanks guys---john
