5 members (Gdads51, TUTS 59, 55shaker, MikeStone1953, Wally / Montana), 138 guests, and 1 robot.
Topics128,109
Posts1,056,258
Members48,437
Long story short: My 66 has the original washer pump. I thought I could change the top of the pump only to find the actual pump inside had disintegrated. I bought the replacement pump from LMC only to have more problems. The pump would not always turn on when pressing the button and when it did turn on, the wheel would turn, but not all the way to turn off the pump.
My question: I plan to use a universal pump next to the original inside the cab instead. Can I use any of the existing wires to power the pump or do I have to run new wires from the existing switch?
1960 Chevy Apache (C10)
1965 Chevy C30 Dump Truck
1966 Chevy C30 Tow Truck
Riding in the Passing Lane
Yes, you can use the same wires as long as your universal pump has 2 terms. & is insulated from ground. One wire is hot all the time, when the ign. switch is on, & it grounds through the button.
1972 Chevy c10 Cheyenne Super
Thanks Wrenchbender...
I thought I was going nuts when I discovered the wiper motor was positive when the key was on. Thanks for confirming this.
I will wire the positive of the new pump to the wiper motor and figure out which wire for the old pump is the switched negative.
