| | | Forums66 Topics128,037 Posts1,055,463 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | Has anyone found a heater core that will work in a Airflow/Fresh air heater? I can't afford $225.00+ for a heater core. Surely there's something out there that can be retro-fit. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if you have a bad/leaky core take it to a rad shop and see if they can re-core it, should be a bit cheaper
Bill | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | Does your heater have the narrow side vent door like the 54 heater? The cores sre different. I have been going through a similar headache but may be able to help if your heater does not have that door? | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | Greg, thanks, but mine is an Airflow out of a '54, so it does have the vent door.
Recoreing costs almost as much as a new core. I was really hopeing that out of all the hundreds or thousands of heater cores out there we might be able to find something that works and wont break the bank. | | |
