| | | Forums66 Topics128,129 Posts1,056,361 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 66 | I removed the west coast mirrors from my '54 to install single arm mirrors. The arms are 19" long. I was wondering if there was a way to keep these arms from flapping up and down while driving. I really don't want to put a diagonal arm if I can avoid it. Also, since I had to drill holes to install a passenger side mirror bracket from the factory holes inside the cab, is there any additional reinforcement needed to stiffen up the cab where the nuts and washers go?
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Task Force trucks have an extra brace that needs to be welded inside the door when adding a right side mirror (don't know it the AD trucks had this or not). The brace has the mounting nuts welded in place so the stress is spread out over a large area. If you don't put a large backer plate in the vibrating mirror will stress the area and crack the metal. Mike B  | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you won't get those extended single arm mirrors to stay still without some angle brace bars, that's why the modern west coast style got popular with arms top and bottom and an angle between .... don't worry, just keep yer foot down, even with the vibration you can still see flashing red lights  Bill | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | If you have not drilled holes yet: I suggest you look for the mounting support brace under the cab/cowl.
When I took my west coast mirrors off to install the long single arm mirrors, I found the braces under the metal had been filed in with "bondo." i popped out the bondo and mounted the single long arms with the braces as it came from the factory. No new holes were needed! I have a 1951 so yours might be a little different. But it s worth looking before drilling...
BTW: I have those long mirror arms inplace for over four years and they have not come loose. Now I did slip once while waxing the top of the cab and nearly broke my neck falling and`catching myself on the drivers mirror arm. I had to readjust that one as it moved. | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Can I ask you where you find those singel extended arms?? I have a driver side mirror only, and want to buy new ones that fits the factory brackets. Mine looks like this: http://i185.photobucket.com/albums/.../BpHom4QmkKGrHqEH-DkEuY-t54vGBLqBb9w.jpgI really want to find another one or two of them including the brackets. Ebay only ? I have searched everywhere, and find only short arms. /Ulf My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Mine are the 1951 version (AD) so you might be asking about the 1954 version(TF). I got mine from a Stovebolt forum member who had them on a truck in his area(NY) of the country. I posted/asked in the Stovebolt "parts wanted" forum and he got in touch with me.
I do not know if the AD mirror long arms are the same ones used on the TF trucks. Sorry. | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | | | | | | Joined: Jun 2004 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 66 | I went to those holes that you mentioned. I might use bigger washers to see what that does. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here is a 1954 GM (Chevrolet truck) accessory mirror arm used on large trucks. This style is a telescoping, single arm, with a rectangular mirror. Other styles were available (round mirror and solid arm, etc). Here are more photos of 1954 mirrors. The drawing shows a light truck with standard arm and standard round mirror, a 1.5 ton truck with standard arm and rectangular mirror, and a COE with telescoping, single arm and a rectangular mirror. Here is information on several accessory mirrors for 1954/55 (Z series) GMC. They offered accessory mirrors on fixed arms, telescoping arms, and had a brace-arm (as a separate part). And, round or rectangular mirrors were available. I do not see a dual-arm brace but I thought they had that available. All these mirror combinations (Chevrolet truck and GMC) were accessories. An owner/dealer might have ordered and used any style arm/mirror/brace on any size truck. I'll check my COE cab against my 1/2 ton cab to see if the mirror holes and inner support/strength brackets under the dash allow all size arms on all size trucks (I think they allow this). | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I happen to have a set of those telescoping mirror arms, from a '54 Chevy COE. | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Sadly they are not the same as on my 59. Otherwise I would have bought them... I will just have to browse on My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
