9 members (Phak1, Bill Hanlon, Rusty Rod, TUTS 59, Napco Man, Cosmo, ndkid275, 2 invisible), 57 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#735857 04/03/2011 3:32 PM
1953 gmc suburban.swung a 235 engine in and it's to short.do i have to change the front x-member? side mounts?
I'm not an expert on this but I would look at making a simple adapter plate, bolted to the original cross member, and then drilled to match the front motor plate on the 235.
You may have to make a fan shroud as well due to the extra spacing between fan and radiator.
pull that short motor out and put a 270 or 302 gmc back in.
ODSS Lawman
ODSS Lawman
Here is a shot from Mike Stark's Webshots page who installed a 261 in a GMC truck. This plate he made will work for your application as well.
GMC Adaptor
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
SWEET #736004 04/04/2011 2:21 AM
yeah, im with bigbadswingdaddy
