0 members (), 38 guests, and 4 robots.
Topics128,089
Posts1,056,004
Members48,430
#734975 03/31/2011 5:18 PM
finally putting together my burb! cant seem to figure out how bottom radiator support plate goes in. any pics would be helpful, nothing in the assembly manual. this is the plate that is slightly bent with the drain hole in it. If anyone has documented pics of this or knows of any links for pics i would appreciate it.
I am not sure what plate you are talking about. The radiator support on the trucks is the same for the Panels & Suburbans on the '60-'66.
I did send you 2 (Don and Tony) photos of what I think that you may be describing Don
ron
its the pan that bolts to the bottom of the frame under the radiator, doesnt hold anything up, just to keep out stuff from blowing around i guess
