| | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | finally putting together my burb! cant seem to figure out how bottom radiator support plate goes in. any pics would be helpful, nothing in the assembly manual. this is the plate that is slightly bent with the drain hole in it. If anyone has documented pics of this or knows of any links for pics i would appreciate it. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | I am not sure what plate you are talking about. The radiator support on the trucks is the same for the Panels & Suburbans on the '60-'66. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | I did send you 2 (Don and Tony) photos of what I think that you may be describing Don ron
| | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | its the pan that bolts to the bottom of the frame under the radiator, doesnt hold anything up, just to keep out stuff from blowing around i guess
