3 members (baldeagle, Shade Baby, 1 invisible),
94
Mod | | | Forums66 Topics128,125 Posts1,056,336 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 81 | I'm sure the question has been asked here countless times, but I have yet find the answer I need.  I have a 1965 C10. I'm looking to add power steering and power brakes. Which year range of other Chevy p/u's can I use to upgrade my 65 steering and brakes? Possibly going to five lug also...? Thank in advance Tim | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | A Saganaw power steering box from a 67 through 87 truck is the most common used. There are several ratios available also. The pump, brackets, & pulleys from cars & trucks from 63 up can also be used depending on what water pump and other accessories you have. You will need to procure a bracket kit for the box and cut the steering shaft.
GM switched to disc brakes in 72, they were also 5 lug. You would need the spindles for the 72 brakes. Most aftermarket suppliers offer kits that use brackets to adapt whatever brake configuration you are looking for. It may be a better way than trying to find parts in a wrecking yard. Fred
| | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | Just helped facilitate this swap for a friend of mine. We picked up a beat up 72 1/2 Ton and took it to a friend of mine's shop where he pulled the front spindles, A-Arms, PS pump, Box, Master Cylinder, and the rear end and swapped them to the 65. Ended up putting a new Master cylinder in as the one off the donor was leaking. Also went with 2.5 drop spindles and drop blocks in the back although it could have been done with the stock spindles just fine. We ended up selling the rest of the donor for about a $150 profit overall with labor I think the whole thing ended up costing about $2500. The truck drives great stops wonderful and now has 5 on 5 wheels. The 72 parts are bolt in with the exception of the power steering pump which will require some bracket work if the truck has the 283. The guy that bought the donor turns out he had all the parts we needed off a truck he parted out a few years ago and plans on putting the truck back together and putting it back on the road.
The only minor thing is the higher ratio rear from the 72 yielded much better highway speeds but the 283 and the Powerglide is a little anemic at low speeds but in this case this trucks hard working days are over it's going to be a fair weather cruiser. Mongo | | |
