1 members (Shade Baby),
152
8
Mod | | | Forums66 Topics128,106 Posts1,056,214 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | I have (at least I think) a 1958 Borg Warner 3speed/Overdrive in the 41 Chevy. Because of a leaking rear seal it toasted some innards.
I wonder if someone has a overdrive sungear sitting on the shelf.
Also looking for a front crank seal for a 261.
Thanks, Frank
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The best place to look would be the Swap Meet (and posting a Want Ad there might get you a quick response). Is this the kind of front seal you are looking for? A parts store should have one - what year 261 engine? | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I see the Borg Warner section on eBay quite often. Most of the parts will interchange with the T86/R10 out of a Ford, and they are a lot more plentiful than Chev. | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | I have the sun gear. Contact me at [email protected]. Fred
