0 members (),
108
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 40 | I've lost power to my fuel gauge. seems as though the male connector @ the fuse box has come lose behind the fuse box.I've tried to remove the box but cant seem to get it to come lose from the floor board.i can get it to turn clockwise a little but that's it & don't want to force it I'm sure it brittle as it's the original. need ideas,send help! | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The factory fuse block is held to the firewall with two 1/4" hex head screws. You must remove two of the fuses, that cover these screws, in order to remove it from the firewall. Upon removal, the fuse block is visible from the backside. | | |
