1 members (KEVINSKI), 160 guests, and 2 robots.
Topics128,108
Posts1,056,230
Members48,436
#735207 04/01/2011 1:32 PM
Work continues on the interior of my '56 half-ton. I ordered a black headliner from Classic Parts. Not sure quite what I expected to get, but i ended up with a thin, black, more-or-less plastic piece with a 1/4" grid feature molded in. I kind of like it - i think it will look good in my cab. The question is: how to affix it to the roof? i would say it is semi-rigid, so it won't need a uniform application of adhesive like a cloth piece would. I do think it will need something to hold it up besides the rubber moulding.. any suggestions?
the spray-on contact cement works
thanks Bill!
Has anyone ever attempted to put a layer of heat shield/soundproofing underneath the headliner in a task force truck? If so, did it work well or mess things up?
gobolt
yes, the peel n stick sort of stuff would be good, but you need to really clean off the original tarry junk or the new stuff won't stick, it needs a pretty smooth surface
i was thinking about a piece of bituthene (ice & water shield) to knock down the drum effect.
same deal, just a different name, works well for sound deadening - but they all have an adhesive side that's a rubbery/tar substance that does not stick well to the crusty dried up residue of the factory treatment - the type I'm using everywhere on daBus project is called Blueskin, which has a 'primer' that can be sprayed first to improve the stick, but it still needs a smooth surface
Tomctomc,
I installed mine from Classic Parts on my 55.2 and I found that the thing was just barely big enough to cover the roof. If I took off the rubber moulding you would see a big gap around the entire thing. Did you have the same problem?
Also, I used 3M Super 77 and it sagged after a day in the sun. Any other adhesives that work better out there since I have to redo it?
There is a 3M Super Trim and Upholstery contact adhesive. It is sold in parts stores. It is pretty expensive (about $20 per spray can). It will hold up your headliner.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
Make sure you use High Temp spray adhesive ... or your glue job will fail the first hot day that comes along.
Here's what I always use:
http://www.yourautotrim.com/perhittrimad.html
Alan
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
Moderated by  ndkid275, Phak1
