2 members (MNSmith, Otto Skorzeny), 92 guests, and 2 robots.
Topics128,130
Posts1,056,717
Members48,454
#735300 04/01/2011 7:18 PM
1 Offline
has anyone used their old vacuum wiper motor with a newer v8? mine is a 1964 283 and i would like to use the original wiper motor (1953), were is the best place to run the vacuum lines on the new motor? I havent had to much experience with vacuum lines on vehicles so im not sure were it would be safe to tap in. I plan on going with an electric motor when the funds are available but for now i would like to at least have something.
I'd go a head and use manafold vaccum.
A vaccum can/resivore of some sort may help as well.
I've already gone elect. found my vac unit is fine, the motor has major vaccum issues - as in leaking intake gasket.
Nutherwords, my orig vac motor is for sale if anyone needs one.
it ain't YOURS 'till it ain't stock!
1951 chevy 3100
Riding in the Passing Lane
If the vacuum wiper is working good you don't need an electric with a v-8 engine. You wont be stepping on the accelerator hard enough to drop the vacuum with wet pavement. I drove one a long time like that & it works better then electric. Hook the vacuum line to the carb outlet that has full vacuum.
1972 Chevy c10 Cheyenne Super
H Online: Content
I'm tinkering with an idea for a vacuum reservoir made of a piece of 3" PVC pipe with caps glued on the ends and a 1-way check valve like a brake booster uses to keep the vacuum from going away when the throttle is opened. Painted black, and tucked away under the cab inside a frame rail channel, it should be virtually invisible to the casual glance.
I drove my 57 10 years with the vacuum wipers and a V8, it worked good I once tryed a vacuum reservoir tank ,about 2 quarts size, it would do one cycle after flooring the truck and after the engine was off,It would, ofcourse, made a difference with larger tank, also need a check valve on the engine side ,BILL
1 Offline
I found a spot to link my wiper motor up to but it still doesn't work, after i pulled it down, i found it was froze up so i pulled it apart and regreased it. It now it moves a lot easier, and it also seems to move a lot farther too. Im going to put it back on the truck this weekend and hopefully it works.
1 Offline
Ive got another question about the wiper, I hooked it up to the vacuum line coming out of the intake,when i pushed the dial one way (closed?) the wiper arm attachment moves slowly until the end of its stroke, then when i move the dial the other way(all the way open?) it snaps quickly until it reaches its full stroke the other way. what would cause this?
