2 members (Otto Skorzeny, GMCJammer51), 62 guests, and 6 robots.
Topics128,180
Posts1,057,145
Members48,463
There seems to be a lot of discussion on Huck to Bendix brake conversion on 1/2-tons (including the technical tip at chevytrucks.org). Has anyone done the front conversion on an earlier Advance Design 3/4-ton? Is the front just as easy as on a 1/2-ton?
I'll be reworking the front end of my '48 one of these days and it's logical to give a look at the conversion there.
Thanks!!!
Wally,
I have a '52 3/4 ton with the original Huck brakes. I just picked up some '53 3/4
ton Bendix front brakes from a fellow bolter to replace my Hucks. Looks to me to be a simple bolt in swap. I haven't installed them yet, I have to do my king pins first. The Bendix fronts are also larger...12" dia. compared to the 11" Hucks. '53 to '55 should be a bolt in, maybe even to '59, but I'm not sure...my parts book only goes to '55.
Steve
'49 3800
'52 3600
'57 3100
Ghostrider,
I wonder about tire/rim clearance. My 235/85/16's just barely clear the tie rod ends now. I guess I'll just have to try it.
I don't think the tire/rim clearance will change at all. By the way...what is a comfortable top speed for you with those tires and the 261/4.10
setup? Also...what dual res m/c are you using?
Thanks...
Steve
'49 3800
'52 3600
'57 3100
I
I Offline
Wally, the Huck to Bendix should be a bolt-in assuming you have all the brake parts and backing plates and drums as the hub is the same.The bearings and spindles however are larger on '53+.
Thanks, Guys,
My own personal comfortable top speed is about 45 MPH but that says mostly something about me driving the '48. It could do a lot more, engine-wise. I've never put a tach on it but I might this weekend.
For the dual MC, I used the adapter plate from CPP and an MC from NAPA.
