2 members (Peggy M, treegrower), 226 guests, and 4 robots.
Topics128,077
Posts1,056,015
Members48,433
Was running ok then recently starting stalling at rest or moving when the accelerator was pressed down half way, you have to ease the revs up slowly. I'm looking for tips before I start tearing the carb apart, sounds like the accelerator pump but could it be a fuel line problem, should I start at the tank and work forward or just start on the carb? Have recently changed plugs, wires, rotor and cap. I'm working on this isn't timing or electrical, but... Doug.
I'm also saying accelerator pump
50 chevy 3100
seems like the only ignition possibility would be a bad vacuum advance
Just for giggles...
WHAT ENGINE ARE YOU RUNNING?
WHAT CARB?
The 58' American GMC had 2 engine options... a 270 six and a 336 V8. I believe the Canadian version had a 235 six or a 283 V8.
There are virtually milllions of other engine/carb combinations out there, and my ESP isn't so good.
I don't think carbs are that difficult to rebuild, but you should check/eliminate the easy and obvious things first. Fuel pump output, spark plug type & gap, point gap/dwell, timing, you get the idea.
I agree that it sounds like the accelerator pump, but it's odd that it started acting up "recently" with "recently" changed ignition parts.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
