8 members (wilbur53, Gdads51, Shade Baby, 68ironhead, Greg_H, rinemb, Otto Skorzeny, 1 invisible),
248
Mod | | | Forums66 Topics128,095 Posts1,056,075 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 4 New Guy | | New Guy Joined: Jun 2010 Posts: 4 | Was running ok then recently starting stalling at rest or moving when the accelerator was pressed down half way, you have to ease the revs up slowly. I'm looking for tips before I start tearing the carb apart, sounds like the accelerator pump but could it be a fuel line problem, should I start at the tank and work forward or just start on the carb? Have recently changed plugs, wires, rotor and cap. I'm working on this isn't timing or electrical, but... Doug. | | | | | Joined: Mar 2005 Posts: 98 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 98 | I'm also saying accelerator pump
50 chevy 3100
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | seems like the only ignition possibility would be a bad vacuum advance
Bill | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Just for giggles... WHAT ENGINE ARE YOU RUNNING? WHAT CARB?
The 58' American GMC had 2 engine options... a 270 six and a 336 V8. I believe the Canadian version had a 235 six or a 283 V8.
There are virtually milllions of other engine/carb combinations out there, and my ESP isn't so good.
John | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | I don't think carbs are that difficult to rebuild, but you should check/eliminate the easy and obvious things first. Fuel pump output, spark plug type & gap, point gap/dwell, timing, you get the idea. I agree that it sounds like the accelerator pump, but it's odd that it started acting up "recently" with "recently" changed ignition parts.
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | |
