1 members (Hotrod Lincoln), 73 guests, and 1 robot.
Topics128,055
Posts1,055,782
If brake shoes get contaminated with brake fluid, are they hopeless? Is it possible to clean them or does the fluid soak in and they cant be saved. I had a leaking wheel cylinder and the shoes got pretty wet. All thoughts and opinions welcome. (at least about this subject)
Thanks, Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
How much wear is left on the shoes - may be a good time to change them out anyway. I think they can be cleaned, check at your FLAPS for what they recommend, but I like the idea of just replacing them.
H Online: Content
I've used every solvent known to mankind, sanded the linings, even heated them with a torch, and I've never been able to salvage fluid or grease-contaminated brake linings. As soon as the brakes heat up a little, more fluid comes to the surface, and they squeal and/or grab. Just bite the bullet and swap them out!
yes, what Jerry says for sure - you can get them clean to work initially, but the fluid that soaked in will continue to wick out forever
Thanks guys. Thats what I thought though I had hoped I was wrong as the shoes have little wear.
HRL, its good to see you back.
Jeff
1957 GMC 150
Unless those are recent brake shoes, don't fool around with them. They could be the old asbestos type. Not good.
Dont bother asking the "kids" at the flaps,,they can barely tie their shoes without supervision.
A question like that and they'll just look at you with a big,,"nobody's home" look.
An old mechanic told me once to soak them in alcohol. Maybe??
Or just get new ones.
Marty
Actually, it depends on how long that have been soaking. If they have been sitting in fluid, grease or oil for a long time, then they are done. If it has only been a day or two, they can usually be salvaged. Cleaning them up with some Brakleen and seeing how they dry up ( or not) will tell you.
1 Offline
Don,t bother with cleaning them I agree. I have tried everything. If you get the cleaned up, using whatever, and dried out just put a small torch to em and you'll see what they mean. Oil will cook out of them forever.
