1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#732671 03/23/2011 10:05 PM
Y
Y Offline
Good Afternnon all,
My name is Yori. I have a 1958 GMC series 100. It ran fine untill a massive backfire which blew out the seems on the muffler. Does anyone have an idea s to what would cause this.
Thanks.
yori #732683 03/23/2011 11:01 PM
Must have become full of fuel. Better check your carb setup. I was once riding in a F%#d pick up with a friend and his catalytic converter loaded up. The truck started snorting and running really rough until KERRRWHAM! Blew the exhaust right off and bent the drive shaft. Unbelievable. Scared the bejeepers out of both of us.
(yeah, I know....friends don't let friends drive F#rds)See what happens?
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #732685 03/23/2011 11:08 PM
welcome to the garage yori - as Dave sez, it could only have been excess gas in the exhaust that got set off by the heat - back in the day we did that on purpose sometimes by turning off the engine at speed for a few seconds without pushing in the clutch, then turning it back on grin BANG big_eek
squeeze #732688 03/23/2011 11:14 PM
Y
Y Offline
Cheers to you both. I have just finished rebuilding the carb and hope to have solved the problem. If weather permits I'll try it this weekend. Here is the truck. Thanks for the welcome. http://profile.imageshack.us/user/yorinski/
yori #732694 03/23/2011 11:36 PM
Nice truck. Hope that solved the problem.
Cletis #732695 03/23/2011 11:42 PM
Y
Y Offline
Good looking trucks, I am jealous of your yard full of them. I also have a 1964 chevy that is my daily driver. SOmeday I'm hoping to get a 38 into the collection.
yori #732763 03/24/2011 4:05 AM
Mine was caused by a loose power connection to the coil.
pic
Could be worth a look.
regards,
Leon
Leon #732925 03/24/2011 6:41 PM
Y
Y Offline
Thanks for the suggestion. I will look into the coil as well. The picture you sent of yours is just about what I am looking at too. On the subject of mufflers does anyone have an opinion as to type and importance, as I will be replacing mine, I thought I might ask.
Thanks again,
-Yori
yori #733017 03/25/2011 1:48 AM
You can start a religious war by asking about muffler preferences.
I use a pair of 22" Smithys on my 235. I ran a single one after the muffler "event" until I got the dual system finished. I like the way it sounds and the low cost of the mufflers.
regards,
Leon
Leon #734773 03/30/2011 10:46 PM
Y
Y Offline
My muffler blow off was caused by a worn out ignition switch. It was esseintally doing the same thing as Leon's loose coil connection.
Yaut #734826 03/31/2011 2:37 AM
Pretty sure both my trucks have the stock style round mufflers. I like the sound alot. Jim Carter has them for like $50.
1951 1/2 Ton 216ci 4spd
1955 3/4 Ton NAPCO 235ci 4spd
1959 1/2 Ton stepside 235ci 4spd
This blown-out new muffler is the result of the timing being off (we had re-installed the distributor on a GMC 270 and rotated it too much trying to set the timing "by ear").
It sounded like a cannon going off.
