3 members (papas52, Jeff Ogden, Otto Skorzeny), 141 guests, and 0 robots.
Topics128,163
Posts1,056,921
Members48,458
I have taken the brake drums of my 1954 3/4 ton 3600 Chevy truck. There was a paper gasket between the drum and the spindle mount. Anybody know where I can get replacement gaskets?
If you really want them you will probably need to get some gasket paper and make them.
That gasket was primarily to prevent rust between the drum and hub, which could cause the drum to stick to the hub. It isn't 100% necessary to replace it. A VERY LIGHT coating of anti-seize will do the same thing.
Bill Burmeister
