0 members (),
133
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 35 New Guy | | New Guy Joined: Jan 2011 Posts: 35 | I have taken the brake drums of my 1954 3/4 ton 3600 Chevy truck. There was a paper gasket between the drum and the spindle mount. Anybody know where I can get replacement gaskets? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | If you really want them you will probably need to get some gasket paper and make them. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That gasket was primarily to prevent rust between the drum and hub, which could cause the drum to stick to the hub. It isn't 100% necessary to replace it. A VERY LIGHT coating of anti-seize will do the same thing.
Bill Burmeister | | |
