| | | Forums66 Topics128,026 Posts1,055,404 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 62 | will the 16 inch 6 lug 1960 rims work on 1948 6 lug hub and cold i use 1948 center caps. thanks | | | | | Joined: Jan 2007 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 83 | Hello oldchevyguy, The 1960 rim should fit on a 1948 . The 1948 centercaps will not fit on the 60's rims though. Jason | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I heard from a usually reliable source that the wheels change occurred in 1961. If the '60 wheels have hubcap clips they should work. If they have the nubs your hub caps won't fit. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | what Cletis sez - the last year for clip-on-caps was 1960 .... the pre-55 wheels have 6 clips, the 55.2-60 have 3 clips, if the wheels have clips they'll work
Bill | | |
