7 members (HandyAndy, 68ironhead, Rexville48, walter74, 6inarow, GMCJammer51, 1 invisible), 80 guests, and 1 robot.
Topics128,035
Posts1,055,567
#734650 03/30/2011 1:50 PM
LDO
Offline
I just got a 57 truck and would like to lower it. Thinking about Sid's for the front but for the rear, my axle sits under the springs and flipping it would probably lower it more than I'd like to so I was thinking of using 3 inch lowering springs. Would like opinions, etc. on those who have used them. Do they really lower 3 inches and how's the ride comfort, etc.
thanks!
LDO #734652 03/30/2011 1:58 PM
What size is your truck? 1/2 ton or 3/4 ton?
wbrowne #734664 03/30/2011 2:56 PM
Use only if necessary
wbrowne #734670 03/30/2011 3:29 PM
LDO
Offline
I'm sorry for the lack of info. It is a 1/2 ton.
LDO #734680 03/30/2011 3:54 PM
Could throw some lowering blocks under her. Sid probably can hook you up with all the parts needed for the rear also.(I think)
How do I get information in this "Sid"
Wait. he will call you dance
gazim #734737 03/30/2011 8:21 PM
lowering blocks don't work on TF trucks since the axle is under the springs. A flip kit, lowering springs, or just removing some rear leaves will get you down in the rear. Type "rear axle flip" into the search box and you'll get hours of fine reading material.
Contact info for Sid is at www.droppedaxles.com
LDO
Offline
Axles are UNDER the springs. I believe a rear flip will lower it too much. That's why I figured on just using 3" lowering springs (for the rear). I called Sid, very nice fella. Seems like he provides everything for the front that I'd need to lower the front while keeping the steering 'stuff' right where it needs to be.
LDO #734852 03/31/2011 3:44 AM
This guy did a lowering job on his apache and it looks good. Was a poor mans job but as long as your not hauling it works.
http://www.jalopyjournal.com/forum/showthread.php?t=477567
Thinking of lowering mine. Mine has factory overloads so I will need new u-bolts before customizing springs. And before anyone says anything. Yes I know its dangerous to remove springs. But it is also dangerous to ride a bike with no helmet but we are all still here today. smile
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
