0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | I recently noticed that my motor seems to smoke blue (I think) out of the exhaust but only on down stroke. It only seems to happen when it is in 1st or 2nd (it's a 3 speed) and I release the accelerator from a high rpm. Even when I rev the motor, it doesn't seem to smoke. The truck has always seemed to use oil even since the motor was built but I had always contributed it to the constant oil leaks that creep up. Most motors that I've seen smoke blue do it constantly, not just on down stroke. I figure I'm going to have to rebuild this motor again eventually but I was wondering what may be causing this. Thanks for any help. | | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | Oil consumption during high-vacuum conditions like coasting at high RPM in the lower gears is almost always caused by piston ring problems. Was the block bored during the rebuild, or were the rings just replaced without a rebore and new pistons? Cylinders wear most in the top 1 inch of ring travel, so a ring is constantly changing diameter to try to stay in contact with the cylinder walls if the bore is even tapered a little bit. At 2,000 RPM, the rings are flexing 66 times per second. It doesn't take long for a ring to lose enough tension to let oil slip past it and into the combustion chamber. Reboring and fitting oversixe pistons straightens out the cylinder top to bottom, and makes the rings last a lot longer. I will not re-ring cylinders that have more than .005" taper. Jerry
| | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | The block was bored .60 (or maybe .40, can't remember) over during the rebuild and fitted with new ones. The motor was experiencing what I thought was piston slap before this. All of a sudden after nearly two years the noise suddenly stopped and this started. Do you think a ring is out? | | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | Hmmmm- - - - -was the piston slap isolated to one cylinder, or was it a general noisy condition? The pistons might have been fitted loose enough to rattle, but the noise shouldn't have suddenly stopped. It sounds like it's going to need a teardown and some very careful clearance measurements. Once I wore out a set of rings in a single cross-country trip from California to Tennessee, simply because I didn't get the honing grit out of the cylinders sufficiently, and 2500 miles of highway driving completely wore the oil rings away. By the time I got to Nashville, it was burning 3 quarts of oil to every tank of gas! The engine was a 196 cubic inch Rambler American flathead six. Jerry
| | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | To me the noise was a general noisy one but I brought it to a mechanic and he seemed to think it was isolated to one cylinder. He didn't seem too worried about it but he wasn't sure exactly what was causing it. It definitely worried me when the noise stopped but it was a break from hearing it constantly. 3 quarts per tank is intense! I don't think I’ve gotten to that point yet luckily. If the problem is major I might just save up some money and build a new motor altogether... I was hoping to get more than 28,000 miles out of this one though. | | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | What engine are we dealing with here? I notice both of your trucks in the gallery have V-8's in them. The usual way to isolate a noisy piston is to short out spark plugs one at a time and see if the noise changes with the cylinder not making power. A loosely-fitted piston will usually quiet down noticeably with the ignition disabled to that cylinder, while a loose rod bearing might change note to a double knock with power off the cylinder. Main bearing noises or valve lifter rattles don't generally change note when the ignition is cut off. Jerry
| | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | The engine is a 350 in my 66'. It is bored either .40 or .60 over, has a large crank, RV cam, 66' 327 heads, an Edelbrock performer intake and a 650 Edelbrock 4 barrel carb. I wish it was still making the noise so I could try to isolate it but I'm not sure if I will ever know now that the noise has gone away. The motor still runs great and is very strong. I change the oil about every 2,000 miles and do the oil filter each time. Picture of the motor if interested but I'm sure that won't help. | | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | Hmmmmm- - - -I can't see the front of the cylinder heads very well, but it appears you've got a set of "Power Pack" heads from a 283 or maybe a high-compression 327 on it. If they have a rectangular pad cast onto the front of the head with a single triangle shape centered on the top of the rectangle, they're not 350 heads. Those are 58 CC heads that will bring the compression ratio on a 350 with flattop pistons up over 10:1. The .060" overbore will add even more compression pressure. I've heard a compression rattle on some engines set up that way that sounds almost like a Diesel.
Do your best to plug up the external leaks, and keep an eye on the oil level. Unless you live in a place that gets anal about oil smoke like Commiefornia, just drive it, and don't worry much about a little blue smoke. Oil is cheaper than overhaul parts, as long as it's not fouling spark plugs! Jerry
| | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | That's probably the best advice I've had so far. I'm not positive but I do believe the heads are from a 327. There aren't too many commie pollution haters here in the Ozarks of Missouri so I'll go ahead and keep on driving it. I'll just have to remember to set aside some oil money alongside my gas money. Thanks a bunch. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | What was done to the heads before they were put on? Did they knurl the guides, or replace them? I have seen some engines smoke under high vacuum because it was pulling oil around the valve guide. Next time you pull spark plugs, do a leak down test. Should tell you if you are loosing compression by the rings.
I rebuilt a Pontiac engine that after about 20,000 miles started smoking a little on start up and again after coasting down from speed. I had asked for bad guides to be replaced, found out later they had knurled the guides instead.
I'm with Hotrod Lincoln about the rings, but this may give you something else to look at if the leak down test seems okay. | | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | I'm not sure what was done with the heads honestly. But thanks for the info, it's good to know. | | | | | Joined: Nov 2004 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 121 | I always thought blue smoke under high vacuum conditions was caused by valve guides. Why it wouldn't do it in third gear is beyond me, unless you are going fast enough that you aren't seeing it as easily. | | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | I'm sure it's doing it in 3rd as well but I haven't had it at high RPMs in 3rd yet as I've been driving around town. It doesn't smoke bad so I probably wouldn't be able to see it smoking at fast speeds in 3rd anyway. | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | | | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | I'm not sure if that is the correct term but it's what I'm calling it for when you let off of the accelerator from a high RPM and there is backpressure on the motor. | | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | I'm not sure if that is the correct term but it's what I'm calling it for when you let off of the accelerator from a high RPM and there is backpressure on the motor. In other words compression braking ?? Dan Bentler | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | there is backpressure on the motor
Sorry - what does this mean? | | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | Over the last few days I've noticed that my motor has inexplicitly quit smoking. The only thing I did was clean and shake the PCV around and reinstalled it. I didn't think that was a cure since it was still smoking immediately after driving it after I cleaned it. I have no idea if cleaning the valve had anything to do with it but I am glad it has quit smoking. | | |
