1 members (Eileen), 99 guests, and 3 robots.
Topics128,079
Posts1,056,310
Members48,442
#733105 03/25/2011 11:23 AM
I have been working on and off on a '53 3800 for a few years. I am looking for brake parts now. It was my grandfathers truck and sat for about 30 years before I started on it. The drums and shoes are there, but the adjusters, hold down clips, and springs were nothing but powder. I can't find these parts in any of the magazines or at my local napa. Is there a place I can find the hardware for these brakes? I need hardware for all 4 wheels. I think '53 was the first year for the bendix style brakes. Thanks for any help,
Josh
Josh,if you post this in the parts wanted you will get more response.
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
I'm parting out a '53 3800, so I can probably help you out. I should have everything you need from the front. I think the rear end on my truck was switched out at some point, so I probably can't help you on the rear. I sent you a pm with some questions.
dh53 #733346 03/26/2011 4:03 PM
3B Offline
Hy Pa Farmer, if your truck has 12" brakes all around then these Raybestos numbers should get your brake shoes under control
adjusting screw spring H407 axle set $4.84 at Rock Auto
hold down kit H4094 axle set $3.67 at Rock Auto
return spring H130 axle set $4.15 at Rock Auto, hope that helps,if you need anything else, or if you have the 14" rear brakes let us know and I'll see what I can dig up.
3B #733916 03/28/2011 11:15 AM
Thanks, those numbers will work for the front. It does have 14" brakes on the back, do you have numbers for them? I tried to look it up on the Raybestos web site but could not find it. Thanks for any help,
Josh
3B Offline
Hy Pa Farmer, if you have any springs from the 14" rear brakes remaining and you could measure them, or tell us the colour of them [if there is any colour left] then I could try and look them up that way. The Raybestos online catalog doesn't list them.
3B #734141 03/29/2011 1:20 AM
3B Offline
Hy Pa Farmer, I found a one ton diff. and managed to get one drum off to take spring measurements. After crossing part numbers from United to Raybestos [because Raybestos does not list the lengths of their springs in my catalog], I came up with
Raybestos p/n H140, axle set, brake shoe return spring $5.90 at Rock Auto
Raybestos p/n H407, axle set, adjusting screw spring $4.84 at Rock Auto, hope that helps, if you need anything more, just ask.
3B #734266 03/29/2011 11:17 AM
Thanks, that should get me going, except a hold down kit for the rear. I tried the raybestos web site, and can find the part numbers you gave, but when I look up '53 3800 chevys I can't find any hardware. 3 of my adjusters are good, but one wheel had sat pretty low in the ground, and the adjuster is gone. Are new available, or do I need to find a used one? Thanks again,
Josh
3B Offline
Hy Pa Farmer, Hold down kit should be Raybestos p/n H4020 axle set $3.37 u.s. at Rock Auto,
Adjuster rear Raybestos p/n H1508 $6.34 u.s. at Rock Auto
Adjuster front Raybestos p/n H1500 $5.35 u.s. at Rock Auto
in future please make a list of all you wish to find, and give as much info as you can, front/rear, drum sizes etc., hope that helps.
3B #735193 04/01/2011 11:13 AM
Thanks for the help, I'd been having a tough time with the brakes, but now I'm in pretty good shape.
Josh
Moderated by  Dusty53
