2 members (Gray_Ghost, RLB),
194
0
Mod | | | Forums66 Topics128,080 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 42 New Guy | | New Guy Joined: Oct 2010 Posts: 42 | Newbie here. Pulled the engine on my '50 3100 today. I think I have a '57 235 cast on Dec 28th, 1956 and assembled in Tonawanda, NY on either January or September 23rd. I'd like confirmation from those experienced members of Stovebolt. Here are my numbers: Block = 3837004 Casting code = L2856 Serial # = TI23H (the second item really looks like an I rather than a 1 .... could I = September vs 1 that seems to mean January)
Questions: 1) Before the casting code is CONV1 .... what does this mean? 2) Just forward and above the fuel pump is a 1" x 2" plate riveted to the block that states SUN MOTOR SUPPLY, TULSA, OK with two numbers on it, in the lower left 57008, lower right CH20 ..... any idea with this means?
Thanks.
Newbie 1950 Chevy 3100 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Most likely, the engine is a reman, with Sun Motor supply being the remanufacturing company.
Bill Burmeister | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | 50 years ago, there were hundreds of engine rebuilders and their engines were marketed through independent auto supply houses as well as Sears and Western Auto. | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Serial # = TI23H (the second item really looks like an I rather than a 1 .... could I = September vs 1 that seems to mean January) The calendar month and date produced are numeric, not alpha. If it were September then you would have a block that was cast in 1956, assembled in 1957 and probably installed in a 1958 vehicle.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Oct 2010 Posts: 42 New Guy | | New Guy Joined: Oct 2010 Posts: 42 | Here's a link to the serial number .... is that a "1" or an "I" and if an I, what does that mean? serial number
Newbie 1950 Chevy 3100 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The casting date is Dec. 28th of '56, the serial number code breask down to January 23. It wasn't uncommon to see an "I" stamped on these engines when it it's really suppoed to be a "1". The number on mine is stamped like that as well, with an "II" right in the middle of the number. The "H" in the code means it was originally from a '57 1/2 through 1 ton pickup with manual transmission.
