5 members (Hotrod Lincoln, tesa, Nick in Manitou, J Lucas, klhansen), 220 guests, and 2 robots.
Topics128,088
Posts1,056,002
Members48,430
Newbie here. Pulled the engine on my '50 3100 today. I think I have a '57 235 cast on Dec 28th, 1956 and assembled in Tonawanda, NY on either January or September 23rd. I'd like confirmation from those experienced members of Stovebolt. Here are my numbers:
Block = 3837004
Casting code = L2856
Serial # = TI23H (the second item really looks like an I rather than a 1 .... could I = September vs 1 that seems to mean January)
Questions:
1) Before the casting code is CONV1 .... what does this mean?
2) Just forward and above the fuel pump is a 1" x 2" plate riveted to the block that states SUN MOTOR SUPPLY, TULSA, OK with two numbers on it, in the lower left 57008, lower right CH20 ..... any idea with this means?
Thanks.
Newbie
1950 Chevy 3100
Most likely, the engine is a reman, with Sun Motor supply being the remanufacturing company.
Bill Burmeister
50 years ago, there were hundreds of engine rebuilders and their engines were marketed through independent auto supply houses as well as Sears and Western Auto.
The calendar month and date produced are numeric, not alpha.
If it were September then you would have a block that was cast in 1956,
assembled in 1957 and probably installed in a 1958 vehicle.
-Tom
1950 Chevy 3100 w/ 1956 235
Here's a link to the serial number .... is that a "1" or an "I" and if an I, what does that mean? serial number
Newbie
1950 Chevy 3100
The casting date is Dec. 28th of '56, the serial number code breask down to January 23. It wasn't uncommon to see an "I" stamped on these engines when it it's really suppoed to be a "1". The number on mine is stamped like that as well, with an "II" right in the middle of the number. The "H" in the code means it was originally from a '57 1/2 through 1 ton pickup with manual transmission.
Bill Burmeister
