1 members (Hotrod Lincoln),
105
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 35 New Guy | | New Guy Joined: Dec 2009 Posts: 35 | I am putting a big block in a 65 k20. I moved the engine ahead two inches for clearance and put a short water pump on. I now have found all of the right brackets for the power steering and the alternator, both of wich are on the passenger side. The problem I have now is what power steering pump do i need, I have two and they both hit the alternator brackets. So if anyone could help I would appreciate it. | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | I thought the power steering pump goes on the driver's side.(?)
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Dec 2009 Posts: 35 New Guy | | New Guy Joined: Dec 2009 Posts: 35 | my bad thats what i mean they are both on the drivers side | | | | | Joined: Dec 2009 Posts: 35 New Guy | | New Guy Joined: Dec 2009 Posts: 35 | I think you are correct, I located all of the brackets today. What do your headers fit, I still need to get a set but having trouble trying to locate a set that will fit.
| | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Sanderson has some nice sets. Get them hot coated directly from them. | | |
