8 members (Jon G, 55shaker, 3100RustyParts, Gdads51, TS3600, Nick in Manitou, Joe H, 1 invisible), 73 guests, and 2 robots.
Topics128,214
Posts1,057,487
Members48,473
#733650 03/27/2011 3:28 PM
Just installed a Magnaflow stainless exaust on my 65 GMC 910. What a great system for a kit everything fit real nice.Had to lop a corner of the panhard bar upper bracket-only modification.
http://s946.photobucket.com/albums/ad304/radical65gmc/
can you tell me what the kit number or part number is,,,i like to do the same?im outside of calgary alberta,i have air bags on all corners,,,,so do you think this will be a problem as my truck will sit right down,,,frame on ground almost,,is there room for such a stance and is there any possible minor adjustment when installing to compensate for lowering of truck so it wont sit on pipes,,,,what im trying to say is ,,, does your system have some room to play with or it stays where it bolts up,,,,thanks Robin
Nice set-up. I am interested in the part number, as well.
The part no. is 16643 by Magnaflow Performance exaust.This part no is for 66-72 but my truck is a 65 GMC coil spring truck,and a long box.My truck has a 4" drop in the rear and I still have clearance. They recomend 1/2 " for clearance.The mufflers and tail pipe do sit up high in the box like stock. there is still travel room for the rear end , aprox 3 or 4 ". Something I dont worry about because I will never carry anything in the back anyways.
Was under the truck tonight and have 5 " of travel on the rear end. the rest of the exaust is not lower than the collecters on my headers so there is lots of clearance.
