1 members (Hotrod Lincoln), 79 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#733623 03/27/2011 1:54 PM
I am putting a big block in a 65 k20. I moved the engine ahead two inches for clearance and put a short water pump on. I now have found all of the right brackets for the power steering and the alternator, both of wich are on the passenger side. The problem I have now is what power steering pump do i need, I have two and they both hit the alternator brackets. So if anyone could help I would appreciate it.
rodwst #733638 03/27/2011 2:48 PM
I thought the power steering pump goes on the driver's side.(?)
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
my bad thats what i mean they are both on the drivers side
rodwst #733696 03/27/2011 6:26 PM
198 Offline
1 Offline
I think you will have to relocate alternator to other side.
This is the set-up I used on my 65, it's for a 1971 402 Chevelle.
[IMG]http://i88.photobucket.com/albums/k190/wetscapes1/DSC_0187.jpg[/IMG]
198 #733824 03/28/2011 2:22 AM
I think you are correct, I located all of the brackets today. What do your headers fit, I still need to get a set but having trouble trying to locate a set that will fit.
rodwst #733990 03/28/2011 5:39 PM
k10 Offline
Sanderson has some nice sets. Get them hot coated directly from them.
