2 members (baldeagle, LAROKE),
26
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 53 | The running boards on my stake bed look like they are from a pickup. Is there any way to tell if the front fender was replaced as well? We have a swap meet coming up next week in Portland. If I can find the correct running boards should I change out the fenders as well? https://picasaweb.google.com/Bompajohntaylor | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Yep, they look like pickup boards. I don't believe the front fenders would be different. You would probably have an extra runningboard bracket. If you switch to the short boards, no big deal, just take off the rear brackets.
Bruce | | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | This was probably a very large pick up truck at one time. The running boards and filler panels behind the cab would attest to that.
The flat beds usually had shorter running boards. | | |
