1 members (LAROKE),
127
Mod | | | Forums66 Topics128,196 Posts1,057,393 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#73352 02/16/2007 9:37 PM | Joined: Feb 2007 Posts: 22 Member | | Member Joined: Feb 2007 Posts: 22 | Hello, I hope someone has some know how in this matter. I am changing my four spd with granny to a Saginaw, and I was wanting to know if some can tell me if there is a driveline that would work without any mods to the drive line. I have a driveline out of a 85 shortbed 2wd and a driveline out of a 79 camaro and a driveline out of my 62 lwb, I do know that the 62 driveline will need to be shortened but I am not sure on the rest. this weekend I am putting in a new engine with this trans and will find out soon. but maybe a little info will go a long way for me, any help would be great. thanks Jon
if its not broke....you didn't drive it hard enough!
#73353 02/16/2007 10:01 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | is this for yer 66? check the spline count on the trans [coarse on the old one, fine on the Sag] and the various shaft yokes, if the right length doesn't have the right spline yoke, they're not hard to switch
Bill | | |
#73354 02/16/2007 10:16 PM | Joined: Feb 2007 Posts: 22 Member | | Member Joined: Feb 2007 Posts: 22 | Yes this is for my 66, sorry I left that out, the old trans has a slip yoke on the drive line and the Saginaw needs a slip yoke in the trans itself. Do you think the u-joints would be a prob? thanks for your help, this is a great site, I wish I found this earlier.
#73355 02/16/2007 11:20 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I think GM Ujoints are pretty universal, check what you need and compare the ones listed for both trans and driveshaft - I've replaced Ujoints on older driveshafts to swap on the newer yokes no problem, and easy to find yokes at the wrecker around here
Bill | | |
#73356 02/16/2007 11:21 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You are going to have to get it made up at a drive shaft shop. Get a yoke to fit the trans., take some measurements & take it all to a drive shaft shop. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#73357 02/16/2007 11:36 PM | Joined: Feb 2007 Posts: 22 Member | | Member Joined: Feb 2007 Posts: 22 | I think I will have to do some more work, thanks for all your help. I will know more this weekend.
#73358 02/16/2007 11:38 PM | Joined: Feb 2007 Posts: 22 Member | | Member Joined: Feb 2007 Posts: 22 | Do you know if I have two different size u-joints, will that throw off the balance or anything else?
#73359 02/17/2007 9:50 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | No. Most drive shaft shops balance them when they are through. You may want to check the pinion angle but if you don,t change the rear engine mounts in won,t change. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#73360 02/17/2007 11:53 PM | Joined: Feb 2007 Posts: 22 Member | | Member Joined: Feb 2007 Posts: 22 | I have a new slip yoke that will fit in the trans, and I have the drive line to use the rear u-joint yoke so I will take it in after I get theengine and trans to get my length. Now I found out my rearend needs rebuilt. the list is getting longer! not by my choice too, anyway, thats the joy of old trucks. I love it
#73361 02/28/2007 6:01 AM | Joined: Feb 2007 Posts: 22 Member | | Member Joined: Feb 2007 Posts: 22 | Well I found out that a slip yoke out of a 70s camaro with an auto will fit the saginaw, took that down to the driveline shop and had the shorten my old driveline, put a new yoke with a standard yoke, well it should work now thanks for all the advice guys, I love this place more and more everyday.
