9 members (carbking, Mike B, klhansen, Youngin' Tut 59, Pete1946, Gray_Ghost, BarryP, dt235sd, 1 invisible),
89
Mod | | | Forums66 Topics128,139 Posts1,056,758 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | I saw this info here just the other day but I'm having a senior moment and can't find it now. I tried the search mod but to no avail. I want to drill and move the two bolts from inside the oil pan to the outside. thanks Larryw
58 gmc 100 with 350 sbc
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | What they do is drill and tap the holes in the bearing cap to use 3/8 X 16 bolts and drill the cam plate and cover to clear the new bolt but for the life of me I can't see why, some say that the larger bolt will change the relationship of the bearing cap, I don't know if it would. Why would you need to remove the cam gear cover and not the oil pan?
Pete | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | Thats it. Thanks cletis and pete. To answer your question Pete maybe down the road someone has to change a leaking front seal it'll be easier for them. Thanks Larryw
