8 members (mvigo, Charles in CA, Rusted Nut, UtahYork, Peggy M, Shade Baby, klhansen, 1 invisible),
80
Mod | | | Forums66 Topics128,074 Posts1,055,913 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 143 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 143 | I'm ready to fit the interior door panels on my '50 3100 and am using the stock replacement door panel from Classic. I noticed that when I install the 2 foam spacers to cover the door control and regulator I still get some interference from the door control. I found this pic in one of the posts that shows a couple of foam spacers to hold the panel away from the door control. http://www.pbase.com/dennygraham/image/121651890My question is this: Even after installing a couple of foam pads in the same location the door panel does not fit flat. It bulges out from the door control and the foam pads. What am I missing? I've loooked at a dozen pics of finished trucks and found that the panels all look flat. Is this an illusion or should I expect some uneven surface on the interior door panel after the panel is installed. Thanks.
It never costs more to ask and it never costs more to think big.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The door panels on my 50 do not lay flat. Made my own foam spacers also.
I believe 49 and earlier AD trucks had the relay installed in the door channel. You can see that in Denny’s pic, the illustration on the bottom. If installed like that the door panel would lay flat.
My relays do not drag on the panel when I open the door.
Good Luck
