0 members (),
91
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 29 New Guy | | New Guy Joined: Mar 2010 Posts: 29 | Hey all, how do I set and check timing on a 1949 216? its a 3100 half ton. Thanks, Dave | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | There was a similar question about timing a 235 a few days ago. Here is a link to the 1951 truck shop manual. If the engine has many years of accumulated crud on the flywheel, finding the steel ball on the flywheel is not easy. Sometimes the dust cover on the bellhousing needs to be removed so that the forward face of the flywheel can be cleaned to reveal the steel ball. Not many engines are as clean as healingbear's. Hoyt | | | | | Joined: Nov 2010 Posts: 63 New Guy | | New Guy Joined: Nov 2010 Posts: 63 | Agreed. I still don't know if the bb/ball exists on my flywheel. I've yet to see it. Thankfully, I inherited one that runs. Good luck!! | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Just pull the plugs & turn the engine over by hand using the fan blade. It'll show up once every turn of the engine. When you do find it, clean the area up a bit & dab some white paint on it. Makes it a LOT easier to see.
Cervoned, take the Tech Tips link at the top of the page.
