4 members (HandyAndy, David Bush, joe apple, 3B), 70 guests, and 1 robot.
Topics128,050
Posts1,055,753
#733231 03/26/2011 1:12 AM
Hey all, how do I set and check timing on a 1949 216? its a 3100 half ton. Thanks, Dave
cervoned #733263 03/26/2011 3:47 AM
There was a similar question about timing a 235 a few days ago. Here is a link to the 1951 truck shop manual.
If the engine has many years of accumulated crud on the flywheel, finding the steel ball on the flywheel is not easy. Sometimes the dust cover on the bellhousing needs to be removed so that the forward face of the flywheel can be cleaned to reveal the steel ball. Not many engines are as clean as healingbear's.
Hoyt
hoyt #733274 03/26/2011 4:32 AM
MLT Offline
Agreed. I still don't know if the bb/ball exists on my flywheel. I've yet to see it. Thankfully, I inherited one that runs. Good luck!!
MLT #733355 03/26/2011 5:21 PM
Ex Hall Monitor
Ex Hall Monitor
Just pull the plugs & turn the engine over by hand using the fan blade. It'll show up once every turn of the engine. When you do find it, clean the area up a bit & dab some white paint on it. Makes it a LOT easier to see.
Cervoned, take the Tech Tips link at the top of the page.
