6 members (TUTS 59, Stovebolt48, 32Fordpuchoptop, Wayne67vert, Oswald, Otto Skorzeny), 83 guests, and 9 robots.
Topics128,021
Posts1,055,348
Members48,420
#732540 03/23/2011 2:53 PM
I suspect that this has been asked and answered many times but here goes. I purchased a single wire 12V alternator from J.Carter and they cannot tell me what the 2 spad lug socket on the unit is for. Their opinion is just hook the main output to the battery and that's it. I'm guessing that Delco put those 2 terminals there for something...? Thanks, David
something for a different application maybe? one of them will be for an idiot light, I think the other is an exciter .... 10SI or 12? - Mad Electrical might ID the unit and has lots of alternator conversion info
If it is a one wire alternator you would be able to hook up to the terminal on the rear of the alternator and it should charge when running. The regulator should be a self exciting regulator that excites from the rpms of the alternator turning. This eliminates the need for the exciter wire that plugs in. There is a block out plug available for those two terminals that really gives the alternator a cleaner look. PM me if you need one. Depending on what S.E. regulator they used it may take "goosing" the foot pedal once to increase rpms to get the alternator to kick in. Hope this helps.
Thanks to both of you. I'll just hook up the output line and go. Bill, I'm going to check out that link because I am curious about what they are there for. Ken,thanks for the offer on the block out plug but I am a long way off from that level of detail. Just trying to put together something to drive.
Squeeze is right about MAD ELECTRICAL.
Compelling information there about alternator wiring as well as
headlight connections.
He saved my bacon with an alternator conversion for an old Rolls Royce...
Replacement Rolls Royce alternator was $750!!!!
He talked me thru converting it with a NAPA Chevy rebuilt for $69 !!
Smart man!
Mike
My 1 wire alternators have a rubber plug in the two-prong spot, sell for about $50 retail
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Squeeze is REALLY right. That is a great link. It turns out that I was sold a "one wire" 10SI that is actually a 3 wire. Glad of it too. Back to reading about alternators. Thanks guys !
My single wire is also 3 wire....I got a new wire harness and it instructed me to put plug into alternator..didn't know what to do with the black wire...called the tech line, I just had to attach it to the rear post...it self excites....
(Sounds like someone I know.. Hmmmmmmm) anyway good luck
http://i1091.photobucket.com/albums/i381/snipewarrior/Internal%20Parts/P1010061.jpg
1954 Chevy 3100 5-Window
More pix on Photobucket
"True victory is victory over one's self."
Krav Maga isn't pretty ... but it works just fine.
Jimmi V.
