1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 16 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 16 | Good Afternnon all, My name is Yori. I have a 1958 GMC series 100. It ran fine untill a massive backfire which blew out the seems on the muffler. Does anyone have an idea s to what would cause this. Thanks.
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Must have become full of fuel. Better check your carb setup. I was once riding in a F%#d pick up with a friend and his catalytic converter loaded up. The truck started snorting and running really rough until KERRRWHAM! Blew the exhaust right off and bent the drive shaft. Unbelievable. Scared the bejeepers out of both of us.
(yeah, I know....friends don't let friends drive F#rds)See what happens? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | welcome to the garage yori - as Dave sez, it could only have been excess gas in the exhaust that got set off by the heat - back in the day we did that on purpose sometimes by turning off the engine at speed for a few seconds without pushing in the clutch, then turning it back on  BANG  Bill | | | | | Joined: Sep 2010 Posts: 16 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 16 | Cheers to you both. I have just finished rebuilding the carb and hope to have solved the problem. If weather permits I'll try it this weekend. Here is the truck. Thanks for the welcome. http://profile.imageshack.us/user/yorinski/ | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Nice truck. Hope that solved the problem. | | | | | Joined: Sep 2010 Posts: 16 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 16 | Good looking trucks, I am jealous of your yard full of them. I also have a 1964 chevy that is my daily driver. SOmeday I'm hoping to get a 38 into the collection. | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Mine was caused by a loose power connection to the coil. pic Could be worth a look. regards, Leon | | | | | Joined: Sep 2010 Posts: 16 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 16 | Thanks for the suggestion. I will look into the coil as well. The picture you sent of yours is just about what I am looking at too. On the subject of mufflers does anyone have an opinion as to type and importance, as I will be replacing mine, I thought I might ask. Thanks again, -Yori | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | You can start a religious war by asking about muffler preferences. I use a pair of 22" Smithys on my 235. I ran a single one after the muffler "event" until I got the dual system finished. I like the way it sounds and the low cost of the mufflers. regards, Leon | | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | My muffler blow off was caused by a worn out ignition switch. It was esseintally doing the same thing as Leon's loose coil connection. | | | | | Joined: Mar 2011 Posts: 65 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 65 | Pretty sure both my trucks have the stock style round mufflers. I like the sound alot. Jim Carter has them for like $50.
1951 1/2 Ton 216ci 4spd 1955 3/4 Ton NAPCO 235ci 4spd 1959 1/2 Ton stepside 235ci 4spd
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | This blown-out new muffler is the result of the timing being off (we had re-installed the distributor on a GMC 270 and rotated it too much trying to set the timing "by ear"). It sounded like a cannon going off. | | |
