2 members (cmayna, Gdads51), 100 guests, and 3 robots.
Topics128,193
Posts1,057,249
Members48,466
#714545 01/23/2011 11:50 PM
I have been wondering if anyone has done a gm diesel swap into a warbird. looking at a old gm 6.2 for a power plant and a automatic trans with a new rear diff.
iirc griggs has done diesel swap stuff, just cant remember into what
everybody is ignorant @ something.the more we work together, the less ignorance there is floating around
Not that I know a lot about diesels but I was going to put one in my 52 GMC 2.5 ton until I drove a 6.2 for a while.I got the truck cheap but it was Gutless!and hard to start in cold weather.Diesels are expensive might as well use one that has some power.
1937 Chevy 1/2 ton panel
There's better choices out there, that's for sure. The 6.2, besides being underpowered, are also bad about the heads cracking between the valves. You might consider either the 6.5 or the 6.6, or even a B4T Cummins.
Bill Burmeister
Sounds like a bad idea to me too. It'll take as much work to fit as a gas V8, (a lot for that model truck) and a 6.2 or even 6.5 is nothing special....
The Cummins 4BT sounds like the best simplest swap for one of those trucks.
www.4btswaps.com
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
U
U Offline
The GM diesels (made by Detroit Diesel) were junk. Go for a 4BT or 6BT Cummins or International DT360.
Please don't confuse the GM made V8 diesels like the 6.2 and 6.5 as being "Detroit Diesels"..... they are not.
Not arguing the junk comment, just they aren't Detroits.
Grigg
---All pictures---
I personally love the old 6.2 and 6.5's. I had one in an 85 K10. The forward band on the 700r4 got smoked after about 50K, but I treated it to TransGo shift kit and a rebuild. Wow, what a difference! If it weren't for the clatter, you wouldn't have known it was a diesel!
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
I'm no expert on the 6.2's or 6.5's, but from what I see folks with them in small trucks don't mind them, and folks with them in larger working trucks for the most part aren't impressed.
The way I see if if you already have one and it runs that's great, run it and have fun. But I'd never set out to find and buy one or spend much money fixing one. For sure wouldn't build a truck around one.
Grigg
---All pictures---
What transmission is required for a 4BT?
1949 Chevy 4400 Grainbed
Photobucket pictures
The taxpayers are sending congressmen on expensive trips abroad. It might be worth it except they keep coming back!
Behind every successful rancher is a wife who works in town.
The link from Grigg's post ,there are many transmissions you can use.
www.4btswaps.com
Grigg
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
For sure check out www.4btswaps.com
You'll find that pretty much whatever transmission you want there is a way to make it work in most cases. Do your own research and factor the cost of making it work into the transmission cost, some options will be better than others, and which is cheaper also depends on what engine/adapters you start with.
Most importantly figure out your gearing from the start, a poorly geared conversion is a waste of time and money and can be quite disappointing.
http://www.onlineconversion.com/bigger_tires.htm
Grigg
---All pictures---
