1 members (RLB),
215
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 19 New Guy | | New Guy Joined: Feb 2011 Posts: 19 | got the 50 running - but I have no clutch pedal- only resistance is the return spring ( removed the inspection cover and the fork an throwout bearing all move but i get nothing. I don't even get any residual drag from the spining clutch- i can shift gears with the engine running pedal out and get no grinding - like the two are completely disconnected. I've if a clutch slipped I;ve always had at least some drag thoughts??
50 chevy 2-ton dump 71 C-20 Suburban 402/400 72 C-10 Suburban 350/3-speed | | | | | Joined: Feb 2011 Posts: 19 New Guy | | New Guy Joined: Feb 2011 Posts: 19 | just thinking out loud but can you have a complete clutch diaphram failure? wouldn't that create a bunch of shrapnel?? there was nothing sitting in the inspection cover when i removed it. just looking for some thoughts / insights before having to tear it all out. the SM420 w/ a PTO doesn't look particularly light.
does anyone have PT #'s for clutch / pressure plate / throw out bearing etc. for these??
50 chevy 2-ton dump 71 C-20 Suburban 402/400 72 C-10 Suburban 350/3-speed | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | maybe it has no disc in it? maybe the clutch disc has no lining left? which may be why it was parked by the PO, who likely opened it up to look and in the process cleaned out the bits  .... yes, those puppys are weighty, but you won't know anything until you take it apart, which will have to be done sooner or later Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I once bought a '53 6100 with the same problem. I found a rat's nest in the pressure plate. Centrifugal force had stuffed it into the works and wouldn't let it engage the disc. pic | | | | | Joined: Feb 2011 Posts: 19 New Guy | | New Guy Joined: Feb 2011 Posts: 19 | I'm kinda figuring its gotta come out. - didn't see a rat's nest in the clutch, but it backfired when i started it and blew a wasp nest up through the carb and then a mouse nest out the tailpipe when i got her running.
50 chevy 2-ton dump 71 C-20 Suburban 402/400 72 C-10 Suburban 350/3-speed | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Sounds like the pressure plate pivets are stuck. If the disc was shot you would still have resistance in the pedal. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
