6 members (MickeyP, VEW, Joe H, Peggy M, Gib70, 1 invisible), 58 guests, and 2 robots.
Topics128,090
Posts1,056,015
Members48,430
#732869 03/24/2011 3:30 PM
got the 50 running - but I have no clutch pedal- only resistance is the return spring ( removed the inspection cover and the fork an throwout bearing all move but i get nothing.
I don't even get any residual drag from the spining clutch- i can shift gears with the engine running pedal out and get no grinding - like the two are completely disconnected.
I've if a clutch slipped I;ve always had at least some drag
thoughts??
50 chevy 2-ton dump
71 C-20 Suburban 402/400
72 C-10 Suburban 350/3-speed
just thinking out loud but can you have a complete clutch diaphram failure?
wouldn't that create a bunch of shrapnel?? there was nothing sitting in the inspection cover when i removed it.
just looking for some thoughts / insights before having to tear it all out. the SM420 w/ a PTO doesn't look particularly light.
does anyone have PT #'s for clutch / pressure plate / throw out bearing etc. for these??
50 chevy 2-ton dump
50 chevy 2-ton dump
maybe it has no disc in it? maybe the clutch disc has no lining left? which may be why it was parked by the PO, who likely opened it up to look and in the process cleaned out the bits wink .... yes, those puppys are weighty, but you won't know anything until you take it apart, which will have to be done sooner or later
I once bought a '53 6100 with the same problem. I found a rat's nest in the pressure plate. Centrifugal force had stuffed it into the works and wouldn't let it engage the disc.
pic
I'm kinda figuring its gotta come out. -
didn't see a rat's nest in the clutch, but it backfired when i started it and blew a wasp nest up through the carb and then a mouse nest out the tailpipe when i got her running.
50 chevy 2-ton dump
Riding in the Passing Lane
Sounds like the pressure plate pivets are stuck. If the disc was shot you would still have resistance in the pedal.
1972 Chevy c10 Cheyenne Super
