2 members (Samantha, klhansen), 308 guests, and 7 robots.
Topics128,162
Posts1,057,042
Members48,460
Well getting ready to swap 7:17 ring & pin gear and hopeing all goes smooth any Eye Opening suggestions. worried about getting pin bolt off heard it was torque
300 pounds I just want to pull it and change the pin gear get the bearing taken off and pressed on new pin gear then change the ring gear..... hope all goes smooth
3B Offline
Hy 67dump, make sure you hold the pinion flange with something, so the gear teeth don't have to take the strain of the pinion nut removal and installation, good luck.
Are you using an impact wrench? If so, a heavy pipe wrench holds the companion flange well. We use a 48" pipe wrench and that absorbs the shock. A 24" would probably heavy enough on a 60 series. I think you will need a 3/4" drive impact because the nut will be rusted tight.
