1 members (Southerntruck), 98 guests, and 6 robots.
Topics128,266
Posts1,058,386
Members48,485
#732567 03/23/2011 4:20 PM
I'm seriously considering installing a T5 in my '50 3100 over the summer. I'm well aware of the advantages of the T5 in our Stovebolts. But, I'm considering my cash outlay.In this area(NJ), I can purchase a fully rebuilt T5 for around $600 with a 12mo. warranty. I can go to a U-Pick and maybe get a used, no guarantee, T5 for +/- $200. I've rebuilt my 3 spd,but never a T5 and don't have a clue as to how hard that would be. So I'm seeking advice on buying already done or used and rebuild myself.
Any thoughts? Note: I do already have an open '55 1/2T truck rear available.
Drew
Riding in the Passing Lane
Around here we get a used one & install it as is. They usually work good. If it doesn't you can snatch it back out & o-haul it or try another one. I've o-hauled 2 of them. They are pretty ornery as trans. go, but if you get the step by step directions off the internet & take your time it can be done.
1972 Chevy c10 Cheyenne Super
I agree with Wrenchbender....I'd hold off on a $600.00 box until you find you need one. I've purchased 5 used mid-80's NWC, mech speedo T5's...some .72's and also .63's from behind the 305 Camaros, running ATF and some running gear oil and I've yet to get one that was noisy or had synchronizer issues.
In spite of having what is considered a rather fragile case, I've hammered the .63's behind a built small block with absolutely no issues. I really don't understand how a box builder could do much of a "rebuild" for $600.00 with them furnishing the core transmission. The rebuild kits are about $300.00, a used rebuildable box $150-200.00 and add labor and $750-800/00 is a reasonable price. If you decide to go that direction I'd make sure he does more than just pop the top and check for synchro/gear damage.
The beauty of the T5 is that it's so darned light and you don't even have to run a cross-member so it's basically drop the driveshaft, pop out the shifter, disconnect the speedo, pop out the 4 transmission to bellhousing bolts and drop the box out. At about 75 pounds a determined guy can muscle a replacement box in solo.
The key is to MAKE SURE that you get your gearing/tire size dialed in to meet you own driving needs.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Thanks to you both. I'll be scouring the used parts yards once the weather is better. And Craigslist. I suppose if I'm patient, I'll find what I want soon enough.
Drew
